Re: Re: Re: Help with Super A
Posted by gene b on June 02, 2002 at 19:21:09 from (67.233.170.87):
In Reply to: Re: Re: Help with Super A posted by Lee_TX (To Gene b) on June 02, 2002 at 15:03:22:
ok here we go take all the plugs out now turn it over with finger in #1 and on compression look in the hole to see that the piston is at the top the timing mark on the flywheel should be at the mark it will say TDC now take of the cap and see if the rotor is lined up with #1 wire if you have a mag it will snap at TDC now place the wires correct in order you have to be ok then as you have lined everything up correct #1 is marked on the cap must have your timing off someplace you can double check the other cycls also have you had the front cover and moved the cam or the gear that drives the mag or dist anywhen #1 is tdc the valves will be closed and there will be the 14thous clearence easier to have all plugs out as the engine will turn over easy and after a few revs you will have the compression figured out to the TEE good luck glad to help gene b
Post A Followup
: Re: Re: Re: Re: Help with Super A
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
