Farmall Tractors Discussion Board
Re: Best place to get a gasket
Posted by Farmall Gray on August 12, 1999 at 15:17:28 from (205.188.193.23):
In Reply to: Best place to get a gasket posted by Ludwig on August 11, 1999 at 13:04:14:
If the carb is full and the line is still hooked up you wont get any flow because it has nowhere to go. It has no air vent. When checking flow from the sediment bowl, either unhook the line, or open or remove the drain plug on the carb. This will give the gas someplace to go. If you start the engine with the bowl empty, it will eventually fill up as the engine uses whatr is in the carb. You can get a new gasket at NAPA made
of rubber. These seem to hold up better than th cork gaskets.
Post a Followup
: Re: Re: Best place to get a gasket
