Re: Re: Re: 1949 Farmall Cub
Posted by Kevin on June 03, 2002 at 11:34:52 from (208.230.117.44):
In Reply to: Re: Re: 1949 Farmall Cub posted by Larry Bate on May 29, 2002 at 17:46:21:
Hi, me again, Cylinders get the most wear at the top, due to combustion, heat, not enough lubrication, etc. As the cylinder becomes worn, it takes on a funnel sort of shape, wider at the top, narrow at the bottom. For new rings and pistons to work right, the cylinder must be a perfect tube, same diameter at the top as the bottom. An inside micrometer can be used to check this. A quick check is to do a cylinder leak down and or compression test. If you take the head off, there will be a ridge at the top of the bore. If you scrape off the carbon and you can't feel the ridge any more you might not have to have the engine bored out. I think you will need to have an experienced mechanic help you out. This kind of work isn't terribly difficult, but you have to have the measurements correct, and every thing has to be very clean upon reassembly. I would suggest that you start reading up on the subject. Good luck, have fun.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
