Re: 450 Slow to Turn Over
Posted by TomH on June 03, 2002 at 17:27:32 from (206.99.145.160):
In Reply to: 450 Slow to Turn Over posted by Red Raider on June 02, 2002 at 19:47:49:
You say you jumped directly to the starter. What about the ground cable? Bad connection/conductor/insulation will cause the symptom you describe.
Post A Followup
: Re: Re: 450 Slow to Turn Over
