Re: Oil Pump Repair Kit
Posted by RPM on June 04, 2002 at 06:25:00 from (63.110.182.225):
In Reply to: Oil Pump Repair Kit posted by Paul Sisk on June 02, 2002 at 18:41:05:
Other than obvious wear to shafts/gears, this pump has a pot metal cover that warps and leaks pressure, check it for flat surface where it bolts on pump housing, new pump from Case-IH is $446.00
Post A Followup
: Re: Re: Oil Pump Repair Kit
