Re: Re: Re: Re: H/460 wf compatablility
Posted by Hugh MacKay on June 04, 2002 at 17:19:18 from (209.226.106.50):
In Reply to: Re: Re: Re: H/460 wf compatablility posted by RPM on June 04, 2002 at 14:12:21:
We have bearing suppliers here in Canada that advertize, "If you bring in your axel shaft and wheel hub, we will match it with bearings, inner cones and seals, providing the hub is large enough and axel shaft is within an inch in length." If that not be the case they can provide a hub to match wheel.
I know a guy who put 656 wheels on a 300, both IH front ends. I priced out 8 stud hubs and bearings for my trailer that is currently 5 stud. I wanted to be able to use same wheels on trailer as 3/4 ton truck These guys can match just about any thing close. No it is not IH or Schwartz stock and probably doesn't have the quality. As Wes said in an earlier post he was only going to tinker with, play with and show it off a bit. Then again these bearings could be comming from same source as CaseIH.
Post A Followup
: Re: Re: Re: Re: Re: H/460 wf compatablility
