Re: 240 float
Posted by Dave_Id on June 04, 2002 at 18:32:39 from (67.250.134.253):
In Reply to: 240 float posted by Austin on June 04, 2002 at 17:44:15:
Does it have the Carter UT carb. I may have a suggestion if it is. I had mine off a dozen times until I figured out that the U-shaped float was dragging against the bowl. Do you have a lot of crap in the tank that has the stand pipe in the gas tank plugged up? You may want to take off the sediment bowl and make sure it's clear. Also, if your tank is real cruddy, and you don't want to seal the inside of the tank, you can install an inline filter from a local auto store. Also check the screen, if you have one, entering the carburator.
Post A Followup
: Re: Re: 240 float
