Re: Re: Re: Re: Re: cub stalls on hills
Posted by Jim Broughton on June 04, 2002 at 22:30:17 from (64.12.105.58):
In Reply to: Re: Re: Re: Re: cub stalls on hills posted by Zim on June 04, 2002 at 19:42:35:
Sounds like fuel starvation to me...like the others said...check your float level in the carb, and if you look at your carb, you'll see a small brass nut near the bottom of the float chamber..unscrew it and take it out.It is actually a small orifice which fuel passes through, check the hole in the end of the shaft,it may be stopped up and you can clean it with a small needle or acetylene "cleaner wire" kit, if you have one. Last, check the governor rod at the carb, sometimes they get "gummy" and don't open properly.
Good luck !!
Post A Followup
: Re: Re: Re: Re: Re: Re: cub stalls on hills
