Re: farmall h smoke question
Posted by Andy on June 05, 2002 at 05:37:59 from (208.137.32.222):
In Reply to: farmall h smoke question posted by bob on June 04, 2002 at 16:29:20:
If your concerned about it, which I wouldn't be, just put some umbrella seals on your intake valves. I wouldn't use the PC type seals because they can deprive the guide and valve of lubrication.
Did you have new valve guides installed when the engine was rebuilt? sometimes machine shops will knerl the guides instead. knerling is ok, if the guide wasn't too bad to start with and the knurl job was done correctly. knurling will hold oil in the guide better for better lubrication. BUT, it doesn't last as long and if the guide was work verry much before the knurling, it wont be effective. Anyhow, the oil is coming from your intake valve guides, but if it is just puffing a little bit of smoke on start up and under hard throttling, I wouldn't worry about it unless it is fouling the plugs out. Just my 2 cents worth.
Post A Followup
: Re: Re: farmall h smoke question
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
