Re: IH 986 Hard Steering
Posted by RPM on June 05, 2002 at 06:13:54 from (63.110.182.225):
In Reply to: IH 986 Hard Steering posted by Mark in Florida on June 04, 2002 at 19:17:25:
Basic start would be Hytran & filter, also gasket and Orings on filter cover to eliminate suction leaks, Hytran color should be caramel, water overload will make color milky. By your description this is only common between 2 systems that are failing in this tractor, PS is run by MCV on clutch housing with its pump, rear hydraulics for hitch and remote valves has pump in the rear frame ahead of left axle low in housing, Hytran reservoir is entire transmission.
Post A Followup
: Re: Re: IH 986 Hard Steering
