Farmall Tractors Discussion Board
Re: H ignition
Posted by RED Blooded on August 12, 1999 at 18:14:30 from (206.74.34.101):
In Reply to: H ignition posted by Ron on August 12, 1999 at 17:04:38:
More than likely the others had been changed over to a distributer system for one reason or another.You just happen to be the only one there who hasnt changed over.What is you serial no. and Ill verify the year model.
Post a Followup
: Re: Re: H ignition
