Re: cub stalls on hills
Posted by Phil Auten (Tx) on June 05, 2002 at 12:42:23 from (63.173.243.183):
In Reply to: cub stalls on hills posted by Bugs on June 04, 2002 at 16:47:46:
One thing that nobody has mentioned is the gas cap. If the vent hole is clogged and the cap seals well enough to the filler neck a vacuum will be created in the tank causing fuel starvation. Choking will overcome this too, up to a point. Next time it stalls, reach up and open the gas cap. If you get a whoosh like air is rushing into the tank, you've found the culprit. BTDT.
Phil
Post A Followup
: Re: Re: cub stalls on hills
