Re: Is a magneto separate from the battery?
Posted by TomT on June 05, 2002 at 12:58:08 from (162.42.198.210):
In Reply to: Is a magneto separate from the battery? posted by Bill S on June 05, 2002 at 06:40:49:
Bill, I hope all this good infomation and fun helps but just a note here, the small wire (usually) attached to a terminal on the side of the mag is used to shut down a running tractor by grounding it against the frame. I made the mistake of thinking voltage should be applied there. Wrong! The only thing I hurt was my pride when I found out what these other guys are saying, the mag makes it's own spark, good luck.
Post A Followup
: Re: Re: Is a magneto separate from the battery?
