Re: 300 Utility -- Hydraulic Strainer Question
Posted by RedRider on June 05, 2002 at 21:24:25 from (65.239.11.27):
In Reply to: 300 Utility -- Hydraulic Strainer Question posted by Kilian on June 05, 2002 at 20:11:14:
To get to the strainer you will have to drain your hydraulic fluid, pull the seat off and then the hydraulic reservor top cover. You will most likely need a new top cover gasket. As for the hydratouch valve, yes you will have to remove the hydraulic lines so you can lift off the reservor cover. Its not a real hard job just a messy one.
Post A Followup
: Re: Re: 300 Utility -- Hydraulic Strainer Question
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
