Re: Farmall A noise
Posted by Andy Martin on June 06, 2002 at 05:39:08 from (12.74.160.251):
In Reply to: Farmall A noise posted by THE TRACTOR KID on June 05, 2002 at 16:41:23:
The impulse coupling gives the magneto a quick flip to generate a good spark when you are cranking the engine by hand. A magneto is just a permanent magnet moving past a coil to create a spark. The faster the motion the better the spark. Lawn mowers have magnetos, a magnet in the flywheel moving past a coil. Crank them very slowly and you may not get much of a spark. Crank a Farmall magneto slowly and you will get a good spark as the impulse coupling trips.
If you don't hear it click you have a problem.
Post A Followup
: Re: Re: Farmall A noise
