Re: Super C steering
Posted by Haas on June 06, 2002 at 15:58:56 from (166.72.245.222):
In Reply to: Super C steering posted by mel on June 06, 2002 at 11:59:47:
The 85-140 oil will be fine in the steering box. You don't need a press to get the bearing off. It's not on there that tight. After you take out the retainer bolt, set it between a couple of 2 by 4s and drive the bearings off with a few sharp blows with a hammer behind a block of wood. The worm wheel gear (sector gear) is just a slip fit on the splined shaft. Comes right off once the top bearing is off.
Post A Followup
: Re: Re: Super C steering
