Re: Re: M seat
Posted by howard on June 06, 2002 at 19:29:07 from (65.172.143.106):
In Reply to: Re: M seat posted by CNKS on June 06, 2002 at 18:22:53:
the pan bolts are 7/16 fine thread and short. yes cut them off and buy new ones. the nuts are welded to the new pan which you can get anywhere they sell aftermarker i-h parts for about $75. I use shock absorber bushings. you need to take both 1/2 inch bolts out and they are rusted in. try to get one loose then oil it good and tighten it back up, then work on the other one. good luck.
Post A Followup
: Re: Re: Re: M seat
