Re: I think I'm falling in love
Posted by joe on June 06, 2002 at 19:31:15 from (66.43.207.226):
In Reply to: I think I'm falling in love posted by Les...fortunate on June 06, 2002 at 04:42:15:
i would get a PTO unit for your 300U, a pull-type mower, and no p/s or TA can be put up with, those are only make life a bit easier on you at times. The 300U will probably have 2 to 3 times more grunt than the B, and if you are going to be doing heavy mowing, like brush cutting, at any sizeable amount, you will want the extra oomph of the 300. And then you should buy the B if you want it, but 300U's are very, very desireable tractors.
Post A Followup
: Re: Re: I think I'm falling in love
