Re: changing seal in super c hydralics
Posted by JD Humm on June 07, 2002 at 01:32:24 from (64.159.123.137):
In Reply to: changing seal in super c hydralics posted by steve on June 06, 2002 at 19:45:27:
I have done this procedure a couple of times, no big deal. The pump just slides off once the lines and bolts on the exterior are removed, the pump has a keyed shaft as I recall. I just replaced the seal and reinstalled the pump, filled the reservoir with hytran and started the tractor up, had no problem priming the pump, just worked the levers back and forth a few times and it was a done deal.
Post A Followup
: Re: Re: changing seal in super c hydralics
