Re: Super C steering
Posted by JD Humm on June 07, 2002 at 01:37:51 from (64.159.123.137):
In Reply to: Super C steering posted by mel on June 06, 2002 at 11:59:47:
One thing I like to do when doing this overhaul is turn the gear half a turn when I replace it on the splined shaft, gives you new gear teeth to mesh with the worm gear and tightens the steering up considerably. Haas is right, it is not a press fit and should come off pretty easy once the large round headed bolt that runs through the assembly is removed.
Post A Followup
: Re: Re: Super C steering
