Re: 1086/rear axle seal leaking!
Posted by RPM on June 07, 2002 at 06:01:28 from (63.110.182.225):
In Reply to: 1086/rear axle seal leaking! posted by D estey on June 07, 2002 at 04:13:50:
Just as you describe, remove wheel, then axle cap, take a look at bearing, could be starting to fail, inner bearing also. Inner tougher to fix, remove housing, while you have gone this far to fix outer it would be wise to check it out.
Post A Followup
: Re: Re: 1086/rear axle seal leaking!
