Re: oil drain plugs
Posted by Hugh MacKay on June 07, 2002 at 20:40:30 from (209.226.247.188):
In Reply to: oil drain plugs posted by Glenn(WV) on June 07, 2002 at 11:19:29:
Farmall and other IH tractors do not have just a plain plug in oil pan. It is a plug with a inch and 1/8 hex head and has a brass washer on it, designed to seal the drain hole. These do not need to be very tight as brass washer is your seal. Take it to finger tight and no more than 1/8 turn beyond that. A good rule for some heavy wrench hands would be to tighten with a pair of needle nose pliers.
Post A Followup
: Re: Re: oil drain plugs
