Re: Removing a Piston from Below
Posted by Gene on June 08, 2002 at 20:00:56 from (64.159.101.238):
In Reply to: Removing a Piston from Below posted by Jeff on June 08, 2002 at 13:10:49:
Jeff: I can't remember(too sleepy) what it indicates when the knock goes away when the plugwire is pulled. ..but you might consider pulling the oil pan and checking rod bearings. That's an easy cheap fix. It would drive me buggy hearing an engine knock. Many on this forum take great pride in making engines run as well as when they were new. Go for a fix? G.
Post A Followup
: Re: Re: Removing a Piston from Below
