Farmall Tractors Discussion Board
Re: What color paint should I use for the rim?
Posted by Stan(VA). on August 13, 1999 at 10:01:37 from (207.79.164.6):
In Reply to: What color paint should I use for the rim? posted by George (Indiana) on August 12, 1999 at 09:02:24:
I have settled into using Rustoleum Aluminum paint. It has good coverage, and turns out great even if you brush it on. Which is a real asset if you compare to the time it takes to mask everything off. Only requirement is a steady hand. My last 5 were done this way and I've been pleased with the results. Leaves more of a metalic look (aluminum) as opposed to a glossy paint. It really sets off that Farmall Red:)
Stan(VA).
Post a Followup
: Re: Re: What color paint should I use for the rim?
