Re: F12 vapor lock???
Posted by MikeH-Tx on June 09, 2002 at 09:22:52 from (199.170.89.142):
In Reply to: F12 vapor lock??? posted by Brian on June 08, 2002 at 11:21:27:
Try something simple before you tear into it. Undo the gas cap and see if you are pulling a vacuum as the gas gets used up. I was, until I drilled a small hole in the cap to relieve the vacuum. Did the same thing you describe.
Post A Followup
: Re: Re: F12 vapor lock???
