Re: Re: Bearing retrofit IH 350 Utility
Posted by big fred on June 09, 2002 at 19:44:55 from (65.219.138.217):
In Reply to: Re: Bearing retrofit IH 350 Utility posted by scott AR on June 09, 2002 at 18:24:13:
Scott, I'm assuming you don't have power steering? Try jacking up the front so the wheels are off the ground, then steering, you should be able to tell then if you have some binding or if something is seized up. If not, then I would say your front end is out of alignment. The service manual describes in excruciating detail how to align it, and if you have improper toe-in, it will steer harder than it should. Tire type makes a difference too.
Post A Followup
: Re: Re: Re: Bearing retrofit IH 350 Utility
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
