Re: Re: Bearing retrofit IH 350 Utility
Posted by joe on June 09, 2002 at 19:45:30 from (66.43.207.226):
In Reply to: Re: Bearing retrofit IH 350 Utility posted by scott AR on June 09, 2002 at 18:24:13:
It could be that tolerances are way off in the gearbox or something. I would start by greasing everything up good and adding oil to the gearbox. Our gearbox was falling apart (literally) before I rebuilt it, and it wouldn't hold any oil due to the 1/4 inch gap between the sides of the box. It works lots better now. I guess I would recommend rebuilding it. While I had it off (you have to strip pretty much everything off the tractor - seat, gas tank, etc) I went ahead and splurged and re-did the TA too, since I already had it down that far. Weight, like a loader, on the front end, also makes it a lot harder to use.
Post A Followup
: Re: Re: Re: Bearing retrofit IH 350 Utility
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
