Re: Re: Bearing retrofit IH 350 Utility
Posted by Frank on June 09, 2002 at 19:51:50 from (198.81.16.168):
In Reply to: Re: Bearing retrofit IH 350 Utility posted by scott AR on June 09, 2002 at 18:24:13:
Scott.....I'm assuming that you have a manual steering box. They're pretty simple but a lousy design. The upper and lower ends of the worm gear on the steering shaft form 1/2 of the bearing races. 5/16" dia balls run on them and are held in place by replaceable cups upper and lower(the other half of the bearing races) Tension is adjusted by shims under the steering shaft housing (4 bolts hold it in place) If you don't have vertical play on your steering shaft, before messing with bearing adjustment, I'd back off the box adjustment screws (one on each side of the box with a lock nut around it) and then tighten each a little and test to see if you get any improvement. Good luck!
Post A Followup
: Re: Re: Re: Bearing retrofit IH 350 Utility
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
