Re: IH 140 Carb Troubles
Posted by HavinFuninMO on June 10, 2002 at 07:26:36 from (64.196.152.3):
In Reply to: IH 140 Carb Troubles posted by Ed Jackson on June 10, 2002 at 07:07:21:
The choke restricts the airflow to an engine to make the air/fuel mixture rich (higher fuel content) for easier starting. Needing to keep the choke applied typically means there is a fuel delivery problem and the choke is limiting the airflow to achieve an acceptable mixture. Start at the gas tank and check the tank for rust, clean the sediment bowl, pull the drain plug out of the bottom of the carb and see if the gas runs out. Dirt anywhere in this system will cause what you describe. I hope this is helpful.
Post A Followup
: Re: Re: IH 140 Carb Troubles
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
