I-240 U PTO stuck engaged
Posted by JimBinTexas on June 10, 2002 at 16:55:32 from (63.122.78.64):
After I finished mowing, couldn't get PTO out of gear. Removed 4 bolts to a cover above the actual PTO shaft. Revealed a shaft with with a bolt in the center and a collar, and 3 more bolts. Please!! I need help.
Thanks. Jim
Post A Followup
: Re: I-240 U PTO stuck engaged
