Re: Farmall 130/not charging
Posted by Lloyd on June 11, 2002 at 07:12:26 from (207.177.71.153):
In Reply to: Farmall 130/not charging posted by mike-ga on June 10, 2002 at 16:42:32:
Maybe your regulator isn't grounded? If you ground the field terminal, If the generator is good, it should charge. If it does, then the problem is either in the regulator (I've heard it's easy to burn them up if you wire them wrong) or the wires themselves. Good luck.
Post A Followup
: Re: Re: Farmall 130/not charging
