Farmall Tractors Discussion Board
Re: info on 22-36
Posted by Farmall Gray on August 13, 1999 at 15:18:03 from (152.163.232.23):
In Reply to: info on 22-36 posted by JASON on August 12, 1999 at 16:47:44:
You can get the filter at NAPA. Just have them
interchange the IH # which is 376375R91. It is the
same filter as the early H and late M. All of the
F-series use this same filter also.
Post a Followup
: Re: Re: info on 22-36
