Re: m.d.
Posted by gm on June 11, 2002 at 21:37:18 from (208.1.215.126):
In Reply to: m.d. posted by bob on June 11, 2002 at 20:44:13:
you could try disconnecting the link to the
pump, and move it to the extremes manually.
Then it would just be an adjustment of the
linkage. If not you will probably have
to take the pump apart and see what is
sticking or broken.
Oh, you should make sure there is oil in the
pump by opening the drain.
If you need another pump, I have one
for $175.
-Greg
Post A Followup
: Re: Re: m.d.
