Farmal Super A hydraulic leak
Posted by Brad Harper on June 12, 2002 at 17:21:42 from (67.232.227.87):
Hi. I recently posted a similar problem but have since replaced the gasket and O rings and have noticed an additional leak on one of the 2 tubes that lead between the reservoir and the pump. It appears that the tube has a small hairline crack when it turns to join the flange on the reservoir.
Can I fix it by propane torch and solder(remove first of course) or does it need a steel/ brass weld.. I have a wire feed welder and access to an oxy acetylene torch...Any recommendations would be appreciated as I do not do this sort of thing for a living.. I am a rookie at this...
Post A Followup
: Re: Farmal Super A hydraulic leak
