Re: IH 244 Differential Lock won't release
Posted by Michael Soldan on March 27, 2009 at 06:18:02 from (24.235.56.69):
In Reply to: IH 244 Differential Lock won't release posted by Illinois Farmall on March 26, 2009 at 18:30:12:
Try hitting the left brake pedal, then the right, then the left as the tractor moves slowly forward, this often will release them. Also spray penetrating oil on all moving parts that you can see, sometimes dirt or rust or a combination will keep the arm/plunger from moving freely(My 584 has a plunger into the trans case, other tractors may vary)
