Re: Super A Hydraulic Touch Control Guage not working
Posted by ScottyNY on June 12, 2002 at 19:27:00 from (151.202.183.113):
In Reply to: Super A Hydraulic Touch Control Guage not working posted by Brad Harper on June 12, 2002 at 17:13:11:
What you took out was a temp gauge, not pressure, and it's a lot like the engine temp gauge. Takes a while of working the hydraulics to even budge it. Mine sat still for nine months, even through the limited plowing I had to do last winter. Took about six hours of mowing on a warm day and the needle never moved with the routine, occasional raising of the mower. It finally came up into the Run range after I'd done a good bit of lifting and dropping of the bar as I finished up the corners and a few odd spots that some other tractor drive must have missed. If you plan to use your system a lot, you'll probably want to get a new cover plate, gasket and gauge to mind the temp. As far as pressure, if you've got your control rods set up right, you shouldn't have to worry about it. If something does go wrong, you'll hear the system whining when the tractor is idling with no hyd. load. My .02. Scotty
Post A Followup
: Re: Re: Super A Hydraulic Touch Control Guage not working
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
