Re: Re: Re: M won't start, have I got a weak magneto coil?
Posted by listen for the snap! on June 13, 2002 at 09:15:58 from (165.170.128.66):
In Reply to: Re: Re: M won't start, have I got a weak magneto coil? posted by Daniel S. on June 13, 2002 at 08:47:20:
If the impulse coupling is working you will hear a loud, mechanical "snap" from the magneto every 1/2 revolution of the crank at cranking speed. The impulse works only at cranking speed - soon as the motor reaches idle the impulse deactivates. A stuck impulse often can be fixed by disassembling, cleaning and oiling.
Post A Followup
: Re: Re: Re: Re: M won't start, have I got a weak magneto coil?
