Re: Super C water pump
Posted by geoff gauger on June 13, 2002 at 10:29:57 from (12.155.240.196):
In Reply to: Super C water pump posted by mel on June 13, 2002 at 09:16:59:
You can try a bearing puller, this is the split plate that goes behind the pulley, a two jaw puller is used to pull on the split plate not on the pulley itself which WILL break if you try to use a three jaw directly on the pulley. Once you get everything in place, heat the pulley and crank on the puller, it will come off.
Post A Followup
: Re: Re: Super C water pump
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
