Re: M running-on
Posted by KURT on June 13, 2002 at 11:47:21 from (63.212.145.113):
In Reply to: M running-on posted by John on June 13, 2002 at 10:59:07:
This doesnt fix the root cause but you may want to put a shut off valve in the gas line, I did and I shut off the gas first until the idle drops to nothing then I turn off the coil switch. The tractor starts a lot easier now.
Post A Followup
: Re: Re: M running-on
