Re: Re: Re: Re: M running-on
Posted by LH on June 13, 2002 at 17:12:30 from (205.188.200.43):
In Reply to: Re: Re: Re: M running-on posted by Jim in Michigan on June 13, 2002 at 15:22:42:
When I worked as an automotive mechanic many years ago. The cold water trick was standard for removing carbon buildup in an older engine. If your afraid of the cold water, tranny fluid or marvel mystery oil will work just about as well.
Post A Followup
: Re: Re: Re: Re: Re: M running-on
