Drain plug
Posted by fred on June 14, 2002 at 18:24:53 from (198.108.217.18):
While trying to remove drain plug from block of o-s6 I broke the head of the plug off.What is the best way to remove the rest of the plug?Can I drill it part way an use an easy out?Should I use heat on it?Plug is cast iron. Thanks for any help, Fred.
Post A Followup
: Re: Drain plug
