Re: loose sleeve in a Farmall H
Posted by Steven@nd on June 14, 2002 at 20:03:37 from (12.15.56.59):
In Reply to: loose sleeve in a Farmall H posted by D.C on June 14, 2002 at 15:07:30:
Yep, use the green locktite. Or else ask for sleeve and bearing retainer. It comes out really thin like water. Have used it on Timkens bearings that turn on the shaft and it works! Have also used it on the Timkens races that turn in the hub on my H and that worked also. I wouldn't tear it all down unless you can easily rock the sleeve back and forth in the bore by hand. If it only slides up and down I wouldn't worry about it - that is how the sleeves went into my H, just a push of the hand.
Steven
Post A Followup
: Re: Re: loose sleeve in a Farmall H
