Re: b farmall throttle lever notches worn
Posted by Farmer Bob on June 14, 2002 at 22:46:40 from (66.152.73.160):
In Reply to: b farmall throttle lever notches worn posted by mark sullivan on June 14, 2002 at 22:20:21:
I'm not aware of availability of the throttle plate. Maybe available as after market. I usually dress up the notches with a dremel tool and grinding disc. It can sharpen the grooves back to original and I also dress the tooth on the lever so it fits into the new notches. Might help also to replace the spring on the post that the handle lever fits onto. Those springs will loose tension after all the years of use.//FB
Post A Followup
: Re: Re: b farmall throttle lever notches worn
