Re: Stuck Motor
Posted by Bob in SE Nebraska on June 16, 2002 at 06:32:09 from (162.40.71.142):
In Reply to: Stuck Motor posted by Joe on June 15, 2002 at 18:59:50:
Joe,
So far I have had to deal with three tractors with stuck engines and I have had different results with each one of them. The worst one was so bad that I had to cut apart the piston and remove it in pieces. For the next tractor I was able to use the PB Blaster, a good size piece of oak and a sledge hammer to remove the piston and the third tractor actually had a very bent connecting rod but the pistons were not actually stuck. For all three tractors I was lucky enough that the cylinder walls only needed to be honed and I installed new rings and it worked very well. Hope this helps. Bob
Post A Followup
: Re: Re: Stuck Motor
