Re: Re: Farmall Super C carb!!!!! HELP!!!
Posted by red2 on June 16, 2002 at 07:14:00 from (216.222.237.131):
In Reply to: Re: Farmall Super C carb!!!!! HELP!!! posted by Cory Hubbard on June 15, 2002 at 15:36:13:
hi i got a farmall c and i had the same problem with my carb on the c.. i fond out that the float was not !! adjusted right. so what happens is your engine will run for a minut or two then it will stop and if you use the chock it will run for a minut or two again .. so adjust your float up just alittle and i bet that will work it did for me ... mark or red2
Post A Followup
: Re: Re: Re: Farmall Super C carb!!!!! HELP!!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
