Farmall Tractors Discussion Board
Re: Determining Bearing Size on Overhaul Kits
Posted by RED Blooded on August 14, 1999 at 04:30:49 from (206.74.34.84):
In Reply to: Determining Bearing Size on Overhaul Kits posted by Greg M on August 13, 1999 at 23:09:38:
The best way to do it is to tear thew engine down first.You may need to have the crank turn on the journals and you should order you bearings for whatever the crank has to be turned down to.If you order standard bearing and you have to turh the crank down the standard bearing will not fit properly.
Post a Followup
: Re: Re: Determining Bearing Size on Overhaul Kits
