Re: Super A , Three Point Hitch
Posted by BIG JOHN on June 16, 2002 at 16:13:37 from (205.188.195.21):
In Reply to: Super A , Three Point Hitch posted by Danc on June 16, 2002 at 15:37:08:
Don't give up on the belly mower. Any type of mower that is rear mounted won't be able to mow the grass that the rear wheels mash down. If you look at all of the pro's mowers, they are all front or mid mount. A good Wood's dealer can figure out what is wrong.
Post A Followup
: Re: Re: Super A , Three Point Hitch
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
