Re: Frozen Engine
Posted by Hugh MacKay on June 16, 2002 at 18:23:15 from (64.228.11.188):
In Reply to: Frozen Engine posted by Guy with a ? on June 16, 2002 at 16:49:41:
A product I have used with some sucess is called Fluid Film. It is made from lanolin. I have sprayed a whole can of this in the four cylinders. I left it for a few days. I would never use anything but crank to free the engine. Even after getting it free I would spend 3-4 days turning engine with plugs out until you get whatever product you use worked down the cylinder walls and rings. You want those rings freed up. If this works and engine is free after about a week I would try to start. With all that liquid in there you will probably have to tow with engine turning to dry it off a bit. Rocking tractor in fifth gear , maybe? Never tow a frozen engine and jump clutch in 5th gear, you will most certainly break something.
Post A Followup
: Re: Re: Frozen Engine
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
