Re: Re: Re: setting Charge rate on 6V generator
Posted by Bob M on June 16, 2002 at 19:37:31 from (24.169.120.138):
In Reply to: Re: Re: setting Charge rate on 6V generator posted by KEN on June 16, 2002 at 11:07:25:
Ken - If the generator you've got DOES have an adjustable 3rd brush, moving it closer to the nearest fixed brush will increase current output. There's a screw on the back of the generator rear end plate that secures the 3rd brush holder. Loosen (but don't remove!) the screw a couple turns, move the brush toward it's neighbor, then retighten the screw. Position the brush so there's 3 commutator bars showing between the fixed and the movable brushes - manual says that's the maximum output position.
Good luck!!
Post A Followup
: Re: Re: Re: Re: setting Charge rate on 6V generator
