Re: Cam Stopped Turning....Is there a Key that Sheared?? Everyone take a guess..
Posted by Dan on June 16, 2002 at 21:34:59 from (12.18.160.159):
In Reply to: Cam Stopped Turning....Is there a Key that Sheared?? Everyone take a guess.. posted by Mr. J on June 16, 2002 at 07:07:08:
Camshaft on my SMTA gave me fits for a time, just wouldn't run right, finally pulled pump and dist and found that cam gear wiggled around a bit, found that keyway had chipped off, probably because gear got loose. replaced the camshaft with a used one from a 400 (per service manuel) and runs great now. sounds like your problem is similar, if magneto turns than the gear is turning so either the key sheared or the hub is broken out of the gear, hopefully the former. good luck on it. not a fun job pulling the front off but not that bad either.
Post A Followup
: Re: Re: Cam Stopped Turning....Is there a Key that Sheared?? Everyone take a guess..
